May 12, 201115 yr Author ok thanks. I bought this bike second hand. It currently had a 10 - 41 sprockets. What will be the effects when I chance to 11-42? GreetZ
May 12, 201115 yr ok thanks. I bought this bike second hand. It currently had a 10 - 41 sprockets. What will be the effects when I chance to 11-42? GreetZ Changing from 10-41 to 11-42 you will make it slightly higher geared,
May 12, 201115 yr Author Changing from 10-41 to 11-42 you will make it slightly higher geared, Less aggressive in lower gears and slightly higher speeds?
May 13, 201115 yr Less aggressive in lower gears and slightly higher speeds? Yes that right, you probably won't notice much difference, but if you just change the front to 11-41 that would be even higher geared. It's personal preference, I use 10-42 and so do most people I know here.
