June 17, 201115 yr Does anyone know where i can get a conrod kit for my 2007 sherco 290 for a reasonable price? best price so far is
June 19, 201115 yr Could be worth trying Kevin Breedon Racing if you don't mind using aftermarket parts although they could be from the same manufacturer that Sherco uses
June 19, 201115 yr Author Have you got a number for them?? I bought the sherco with the motor out as the dude i bought it from had an off and the throttle had revved flat out until the bigend siezed up!! the piston and barrel is perfect though!
June 20, 201115 yr Have you got a number for them?? I bought the sherco with the motor out as the dude i bought it from had an off and the throttle had revved flat out until the bigend siezed up!! the piston and barrel is perfect though! Lok at it this way, still about the same as a top job with fresh chrome, even with new bearings and seals. Surely you figured in some when you bought it?
June 20, 201115 yr Author Lok at it this way, still about the same as a top job with fresh chrome, even with new bearings and seals. Surely you figured in some when you bought it? Yeah the price was right and i new it would be a rebuild anyway..!
