BSA C15 Trials Project
Splashed oot last week and bought an Electrex World ignition for Alf.Fitted it and
it started fine but the carburation seems miles out.The bike ran fine on points and
​pulled cleanly from the bottom end now it coughs quite abit and throttle response
isn't that sharp.The plug is sooty and before ignition was a nice brown colour.The carb
is brand new from Amal and as I said ran perfectly before the ignition.The exhaust
isn't clean and the bike smells rich and on the over run sometimes spits oot blue flames.
I set up the timing using a degree disc(rupert ratio book).The carb is running a 110 main
jet could any one please advise me on jetting or ignition timing any help would be much
appreciated as I have entered Alvie which isn't far away.
cheers the noo Brian
  • Replies 82
  • Views 50k
Most Popular Posts
Hey Broony,
seems kinda odd that carbie was fine before and with lecky sparx is not. I would say there's somtehing amiss with the new spark set up.....or your float is jammed and flooding the motor????
Good Luck.
Hi Brian, you sure timing is right ?
Have you cleaned the carb ? Also have you checked the float level, I have a adapter for the drain plug if you need it.
Hi Ross,rechecked the timing as per instructions.Found a Dutch website
that sells the same ignition(think they import them into Britian through
Electrex World),and followed their set up instructions.The timing was out
about 10 degrees.The bike runs alot better carburation needs a tweak
(don't want to upset the neighbours).Seen the entry list for Alvie looks
mega.
Cheers Bashplate,really looking forward to it.
Worth checking float level anyway as they don't to be set "consistently"
Also a heat shield will improve hot starting if you havnt fitted one already.
Ross any chance you could bring your adapter to Alvie so I can check
the float height(I checked it and it was too high and set it but didn't
have an adapter so done it using the fuel tap and checked when the
needle switched off).
Hey Broony,
Good Luck.
Hi, I had a similar thing with my B40 a few years ago, running Boyer Bransden the engine ran quite well, fitted PVL system and it was transformed. Weakened the mixture a little and it got better. I don't know much about Electrex world, but I can recommend PVL, proper hot spark from kicking speed upwards. Dave
Edited by broony
Bashplate, the reason the picture is soooo small is the original
photo was from somewhere else.The original photo is alot bigger
and shows my scorecard hanging from the number board (not a nice
straight line on the left hand side-more of a zig zag :D )
What, Google Earth ?
