stevecollie Posted October 2, 2011 Share Posted October 2, 2011 Well........................... I managed to break the gear select shaft today I aint no mechanic But is there a quick fix Or is it a full engine out job I have a fantastic welder I can use................. Is it weldable is welding advisable? Thanks in advance Quote Link to comment Share on other sites More sharing options...
cabby Posted October 2, 2011 Share Posted October 2, 2011 It's f*cked Time to retire before you break anything else Quote Link to comment Share on other sites More sharing options...
munch Posted October 2, 2011 Share Posted October 2, 2011 casing off on clutch side , no engine out Quote Link to comment Share on other sites More sharing options...
stevecollie Posted October 2, 2011 Author Share Posted October 2, 2011 casing off on clutch side , no engine out Thanks Is it an easy job Or do you have to be compitant Quote Link to comment Share on other sites More sharing options...
stevecollie Posted October 2, 2011 Author Share Posted October 2, 2011 It's f*cked Time to retire before you break anything else You missed a really good day today And if you have nothing positive to say .............move along Quote Link to comment Share on other sites More sharing options...
big john Posted October 2, 2011 Share Posted October 2, 2011 Make no mistake here "Munch" is THE man to discuss any 4RT issues with, listen to him! Big John Quote Link to comment Share on other sites More sharing options...
stevecollie Posted October 2, 2011 Author Share Posted October 2, 2011 Make no mistake here "Munch" is THE man to discuss any 4RT issues with, listen to him! Big John Thanks! I will take his advice I have the big owners manual and an exploded view of the shaft I'm just a little scared that bit's will ping out all over the place once I take the casing off Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted October 2, 2011 Share Posted October 2, 2011 live a little, learn alot. Quote Link to comment Share on other sites More sharing options...
munch Posted October 2, 2011 Share Posted October 2, 2011 nothing too scary, if in trouble contact me . Quote Link to comment Share on other sites More sharing options...
stevecollie Posted October 3, 2011 Author Share Posted October 3, 2011 (edited) nothing too scary, if in trouble contact me . Thank you very much While I'm in there should I change the clutch plates If yes, what do you recommend I should use Edited October 3, 2011 by Stevecollie Quote Link to comment Share on other sites More sharing options...
