October 18, 201115 yr Hi I have just changed my bike 2002 scorpa for a gas gas I am very impressed with the upgrade . Does anyone know the best place to get some good quality carbon or carbon look engine casing guards for both sides ?
October 18, 201115 yr Try trick bits http://www.trick-bits.com/index.php?route=product/category&path=40_50
October 19, 201115 yr Author Try trick bits http://www.trick-bits.com/index.php?route=product/category&path=40_50 Thanks for that . Is 90ml of synthetic 2s oil to 5 litres of fuel still good for gas gas txt 250 the same as my old scorpa ?
October 19, 201115 yr 90ml is too much. I use 75ml but thats too much too. Experts say 80/1 wich is more like 65ml I believe.. -Jan
October 19, 201115 yr The book says 50:1 but it is too much and keeps fouling the plug, I use fully synthetic oil at 70ml to 5Ltrs (70:1) and it runs ok!
October 19, 201115 yr Author The book says 50:1 but it is too much and keeps fouling the plug, I use fully synthetic oil at 70ml to 5Ltrs (70:1) and it runs ok! Well if thats good enough for you with a 2010 I will go with that !!! Thanks .
October 21, 201115 yr Author Just fitted my new bits from trick bits thanks for the tip they look good and will offer some protection both engine cases and an exhaust one.
