November 9, 201114 yr Bought the complete bike with title for 75.00 the other day. The top end is good, crank has almost zero play. But when i tried to kick it over, it wont budge like its seized. Started to dissasemble and found the kick starter gear is missing a few teeth, but no big chunks of metal came out of the left side cover when removed. When I couldnt source out a gasket kit, I stopped and decided to try and find answers online. Another thing, is the clutch hydraulic on these? Im guessing that it is from the white tube and fluid that came from it, but want to be sure. \ Finally if it is possible to save the motor, can parts be sourced in the USA? Or a wiring diagram? I guess if not possible ill be parting it out this winter.
November 9, 201114 yr Contact Bill Pye on 01642 722378 www.Frankfieldfantic.co.uk or Bill Wight www.fanticTrials.co.uk (0)1934 510333 If anyone has info and parts it will be these guys The clutches were hydraulic, they used cycle parts from what i remember.They are a capable bike in the right hands. Good luck
November 9, 201114 yr start first by contacting Mike Komer at the Tryals shop in NY. He has many Fantic parts still in stock
November 9, 201114 yr Parts list here. Wiring diagram here. Best of luck fixing it up, Fantics are nice bikes.
November 10, 201114 yr Author thanks much everyone! my bottom end may be too much bad to try and save though, all the gears are chewed and the shifting links are broken.
