November 17, 201115 yr Does Beta specify a squish clearance for the Rev 3? They do offer base gaskets in different thicknesses.
November 17, 201115 yr Yes, Go to American Beta, I believe its under SUPPORT, you will find a service manuel.
November 17, 201115 yr Author Yes, Go to American Beta, I believe its under SUPPORT, you will find a service manuel. I found one for an evo but not Rev3. I wonder if they are the same? It is kind of odd to do that with a straight edge. I have always seen solder.
November 18, 201115 yr 1mm - 1.5 would be about std. more for softer engine. Less for more go.. That's generally where I set my engines. If you want to be super accurate, use two pieces of soft solder, front and back, which will compensate for piston rock and give a more consistant measurement. Jon
November 21, 201114 yr Beta does offer a thin base gasket. Its availiable through the American Beta website or your local dealer. http://www.americanbeta.com/beta-trials-accessories.html Edited November 21, 201114 yr by Liviob
