Beta Evo Fork Spring
Does anyone know of a source for Evo fork spring that is heavier/stiffer than the original?
Thanks
Thanks
Any U.S. Beta dealer will be able to get them for you direct from Beta.
Front fork springs .88 no longer available due to wire supplier can't supply spring maker with that diameter wire. I have been told that a .90 will be available in a couple of weeks and the .92 is available now I believe. See you local dealer they should be able to help you.
Have you tried less air gap etc first? Less damping if you need more bounce?
Call these fellas. They probobly have them in stock. I bought a set of springs from them for my Evo 290. I weigh 250 and their springs are working fine.Ask for Matt Henry.
http://mcrsuspension.com/
Edited by Liviob
  • 1 year later...
Can you give me more info on air gap adjustment
Std is 120mm on the spring side, how much do you change?
