March 26, 201214 yr Hi Bought a tlm 260 a while ago and I'm in the process of fixing it up and need some bits, mainly a piston 1st oversize and air filter. Parts for these bikes seem very thin on the ground so not sure where to start looking. Bike is a runner, got new rings and small end but it needs a piston and re-bore.
March 27, 201214 yr Good look with your search, parts are like the steam off rocking horse poo. Air filters should be easy to get round and from memory the RTL 250 which Dave Renham of Inmotion had new ones made fit. if you source pistons let me know as I have 3 engines on standard bore!!!
May 8, 201214 yr Did you have any luck finding an oversized piston and ring set. I'm look for one for a TLM200
May 8, 201214 yr TLM200 is a totally different engine, it was derived from the watercooled MTX200 range, I do not know for certain but this must be a good bet that the pistons are the same.
October 3, 201214 yr Author I think I might be able to find a suitable piston for the 260, still checking though
October 5, 201214 yr Had the same problem with a Pentax TLM260. I went to P.J. Motorcycle Engineering (you can find them on the net) who found a piston that fitted and bored, etc. to the correct size. From memory it was from something like a TZ Yamaha, but don't rely on my memory.
October 20, 201214 yr hi someone i know had the same problem of not being able to get a piston, so he had one made it comes complete with rings,since then he has had another made for someone else he can be contacted via rob.wrayford@facebook.com hope this helps
