Gunson 77111 Spark Plug Cleaner - Advice
brucey
Looking at my increasing collection of Cub spark plugs that have virtually no wear (less than 8 hours use) but have been removed because they are 'sooted' up, I decided to take the plunge and invest in a Spark Plug Cleaner.
Basically it is a mini bead blaster that plugs into a compressor air line.
Before you respond, I am also taking steps to resolve my dirty plug habit!
I note that the cleaning medium is cast iron balls rather than sand (silicon) and have ordered a spare bag as I have no idea how long it will last.
Does anyone have any experience using one of these devices and/or any tips? (not spark plug tips!)
If not, I'll let you know how I get on. These tools seem well suited for trials bike applications where wear isn't the issue although I do have a reputation for rash impulse buying things I don't really need (my wife has banned me from Aldi!).
Bruce.
1. Too easy and I thought wire brushing plugs was a bit of a 'no no'.
2. A wire brush may not reach those little crevices!
Anyway, I see it's arrived, so I'll unpack it and give it a go!
  • 1 month later...
I had a similar thing years ago, but used fine silica grit and an electric impeller arrangement instead of air, ran off a car battery. Worked a treat, sadly it got nicked and I couldn't find a replacement, good luck with yours. Dave
They do clean the plugs ok.............but the grit can stay in the plug trapped in the tapered cone between insulator & the metal body of the plug so do air line clean very carefully.
Better though to get it running right.
Edited by trialsrfun
Blimey that takes me back 30 yrs, i had a silica based one on the bench and used to clean a selection of plugs before each Trial - 2 for each pocket if memory serves me right, so there was equal weight distribution in my TT Leathers jacket :chairfall:
