boogieman Posted May 23, 2012 Report Share Posted May 23, 2012 Hi all, I've not long got a 2010 txt pro 300. Daft question I'm sure, but does anyone know what the green fluid that is gathering between the engine and the sump plate and then dripping through the hole in the sump plate, is? I will hazard a guess and say it's the green mineral fluid for the clutch? (only as it says it on the clutch cover) Anyone have an idea how or where it is getting out from, I can't see anything coming off the outer cases? cheers Baz Quote Link to comment Share on other sites More sharing options...
lee99780 Posted May 23, 2012 Report Share Posted May 23, 2012 The only place the clutch fluid could leak from to get down there its the banjo bolt or the pipe coming from the master cylinder. What colour is the oil through the spy glass in the cover? Its more likely to be that, if the slave was leaking it would mix with the engine/ gear oil as its internal. Not a bad job to do either though, ive just done mine Quote Link to comment Share on other sites More sharing options...
neilh Posted May 23, 2012 Report Share Posted May 23, 2012 i reckon its coolant dripping from the radiator. Quote Link to comment Share on other sites More sharing options...
mudboy Posted May 24, 2012 Report Share Posted May 24, 2012 Yes its coolant. They easily leak from the hose connections, the overflow from the rad cap or worst case a broken radiator or head. Quote Link to comment Share on other sites More sharing options...
ianwilson Posted May 24, 2012 Report Share Posted May 24, 2012 Do you have Motul gearbox oil ? If you have it will show as green through the inspection window. I had the same trouble with a 2011 Pro . It turned out to be caused by the sump plug bottoming out before it completely compressed the copper washer. The solution was 2 copper washers which fixed it immediately. Quote Link to comment Share on other sites More sharing options...
boogieman Posted May 24, 2012 Author Report Share Posted May 24, 2012 Hi guys, thanks for the input. My tranny oil is bright red in the window and looks undiluted. I hadn't thought of coolant as the fluid is quite thick. Although having said that she did overheat briefly the other day. I'll pull the tank and check the level and hoses. Quote Link to comment Share on other sites More sharing options...
neilh Posted May 24, 2012 Report Share Posted May 24, 2012 its probably leaking from that stupid excuse for a rad overflow Quote Link to comment Share on other sites More sharing options...
