July 13, 201214 yr Hello iv just gone from a 2002 sherco 250 to a 2004 rev-3 250 and im finding im getting really bad finger cramp after a while making me loose control of the bike. i could ride my sherco all day without a problem. the only differance from the sherco to the beta that i can see is the sherco had short levers on and in my eyes i think that would of made it worse. iv got smallish hands do you think its better with the short levers as the stroke my be less which would make it easier to ride can anyone give me any advice on how to make it lighter. cheers Darreb
July 13, 201214 yr Agreed, try the clutch mod first. I have just done this on a 2006 rev 3 270 and the difference is amazing. Regards Sparky
July 13, 201214 yr I just removed a couple of springs to no ill effect (on a 200). Might be different if you're a full bore mud merchant down there.
July 14, 201214 yr Have you greased the lever pivot and adjusted it correctly for your hand span? Is it the same angle as the Sherco? If it angled down or up from where your used to you will get an effect. I'd also take the opportunity to bleed the clutch and change your oil. Once all this is done ride it for a month before ripping it all to bits and changing things that might not need it. You need time to adjust to it as well.
July 14, 201214 yr Author Thanks you everyone for your suggestions I will have a look into it and try Cheers
July 15, 201214 yr just spent all afternoon on my rev3 270 after doing the clutch fix, no arm pump what so ever was much easier to ride definately recommend it. looking forward to the next trial now
July 17, 201214 yr I did the clutch mod to my 290 and added 3mm thick Army navy washers under each spring bolt to reduce preload on the spring. Very easy one finger clutch pull now. You will have to grind down the cross hatch inside the clutch cover or the bolts will rub the cover. I did this mod about 2 years ago. Still no clutch slipping.. Edited July 17, 201214 yr by liviob
July 17, 201214 yr I found them at the local ace hardware store. They are washers that fit under a allen head bolt. They are the same diameter as the allen bolt head and look more like a spacer than a washer. The fella at the store said that they were called army/navy washers. I told a machinest friend who rides a beta about them by name and he recognized them by name. Edited July 17, 201214 yr by liviob
July 18, 201214 yr Your Welcome. I installed 2mm thick flat washers under the clutch springs of my rev3 250. I didnt have to grind down the cross hatch, but the lever pull is not as light as using the 3mm A/N washers. I will be changing them out soon. I have ridden the 2012 evos and the lever pull is almost as light as the 3mm washer feel. Edited July 18, 201214 yr by liviob
July 18, 201214 yr Hmmmm. I might have a look at that. I don't tend to suffer from girly hand/fingers on the clutch side though? When I chnage my clutch I may add these washers.....
