Rev 3 Brake Pedal Removal?
mcman56
What does it take to remove the rear brake pedal on a Rev 3? There is a nut on the inside but not adequate space to get a standard thickness spanner on the nut. I can't even get calipers in there to measure the nut size. It looks like the most direct method is to remove the swing arm but I'm thinking there must be an easier way.
  • 3 weeks later...
I know that you've probably got it out by now, but with the pivot bolt out, get someone to sit or push down on the back of the bike as hard as possible. This moves the swinging arm up and allows you to pull the lever out.
Edited by overdale
