Rev3 Flooding
my 04 rev 3 keeps flooding I've done a service new plug and air filter etc, cleaned out exhaust, air box and carb, changed out the fuel an still cant get it to go??????? can any 1 suggest something else
check for spark, Beta stator gremlins may have struck.
yea good spark, it fires the first kick then floods, possibly a carb problem???
Sounds like a stuck float or worn needle valve seal in the carb.
Turn the fuel off, drain carb, take the plug out and clean the insulator etc so it's dry (leave out at the moment). Kick the bike over 20 times to expell any excess fuel. Plug back in. Fuel on and try a normal start procedure.
If the fuel floods again then its your valve or floats. When were they last set properly? Is this a sudden change of how it starts/works or has it got worse over time?
Two things
1) You can have spark with the plug out but if you have a weak stator it may not spark under compression
The best test is a spark gap tool
2) Old gas might not burn no matter what you do
When a bike is flooded, the crankcase has a puddle of fuel in it and it can be very hard to get rid of, this explains why it fires then fouls the plug, if its bad enough you can hydraulic lock it and bend a rod so plug out in a warm room for a day or two usually fixes flooding, kick the bike once in a while to sweep the liquid fuel up from the bottom so it can evaporate
Also, flooding is a result not a cause, it's bad sealing of the needle and it will be happening constantly
The effect is high fuel height and can make your bike run rich
Outlaw Dave's trick is toothpaste and a Q tip to clean and polish the seat
Edited by 0007
Thanks for all the help and advice guys, got er going last night, float was stuck a bit, removed and cleaned once again and she fired after a few kicks, seems to running fine now, regards R
