Position Of Rubber Bashplate Cushions On 4Rt
barfy
Does anyone have a photo of exactly where the rubber cushions fit between the bashplate and bottom of the engine?
I’ve tried to fit them like the best I can make out from the pictures in the manual, but whenever I put the bashplate on the small one seems to slip around. I normally pull it out so that I don’t lose it during a trial.
Cheers
Thanks Guys that is most helpful.Glueing into position would keep them in place, but I can see from your pictures that they seem to there is quite firm contact from the bottom of the engine. I;ve printed the photos for next time I change the oil.
Position looks ok but also looks like a std bash plate. A mitani or similar will not distort as much and hence not compress rubbers so much. I have in the past siliconed mine in place especially if you straighten out a used bash plate.
