June 19, 200521 yr Mine suddenly started making a knocking noise and it turned out to be the tank rattling at certain revs. Try slackening the allen bolt and repositioning it a bit. Roy.
June 19, 200521 yr Mine suddenly started making a knocking noise and it turned out to be the tank rattling at certain revs. Try slackening the allen bolt and repositioning it a bit.Roy. Ah yeah - remember that one happened to mine too. Put a rubber washer between the tank and the frame where it bolts on. Or when you hear the rattle, just push your knee against the tank to see if that's it.
June 21, 200521 yr Author cheers for the advice lads il give all these things a try new chain and sprockets sounds a good idea and i will get back to you
June 21, 200521 yr probably find its a link in the chain thats starting to sieze. Sounds for all the world like a knocking in the engine.
July 1, 200521 yr is it an 05 because alot of 05's have a lot of clutch nock, i think if idleing and you pull your clucth in it should stop?
