August 16, 201313 yr Hi people's I've just bought it today and needs a few things to make it 100% trials ready It needs wheel bearings back and front, and I am not sure on size? Are they same size back and front? Should I go for the fast or slow action throttle? Bare in mind I am a novice! Also plug size? BPR5ES? ACU license? Do I need one before I do a trial? Or can I just get a day one just to start? There is probably more I will need to know as its my first trials bike in 7 years lol any help will be grate!
August 16, 201313 yr Confused: Why would a new bike need all these things done to it to make it trials ready. Has it been sitting in crate that long? Edited August 16, 201313 yr by billyt
August 16, 201313 yr Hi people's I've just bought it today and needs a few things to make it 100% trials ready It needs wheel bearings back and front, and I am not sure on size? Are they same size back and front? Should I go for the fast or slow action throttle? Bare in mind I am a novice! Also plug size? BPR5ES? ACU license? Do I need one before I do a trial? Or can I just get a day one just to start? There is probably more I will need to know as its my first trials bike in 7 years lol any help will be grate! Congratulation! What size? 300?? Bearings rear: 6004 2RS Bearings front with Marzocci forks 6905 2RS (With standard forks 6004 2RS) Spot on regardng the plug Try the standard throttle first. If problems, consider change. Dont know nothing about license rules Enjoy! -Jan
August 16, 201313 yr Author Congratulation! What size? 300?? Bearings rear: 6004 2RS Bearings front with Marzocci forks 6905 2RS (With standard forks 6004 2RS) Spot on regardng the plug Try the standard throttle first. If problems, consider change. Dont know nothing about license rules Enjoy! -Jan thanks that's a grate help! It's a 250 pro 2006Which is a standard throttle? As I've only seem to of found fast or slow action. As I wanna change it as its got too much play in it due to the usual wear! Can't wait to ride it but don't wanna use it until its set up correct, so will need your help guys Edited August 16, 201313 yr by monty_trials
August 16, 201313 yr "Fast action" is the standard throttle. Its got white tube. The slow action throttle got a black tube. You dont say your age, but I assumed you have done at least most of your first 20 years? 250 is a good choice and yo should cope OK with standard throttle. Most adult people make the mistake thinking they need a 300... -Jan
August 17, 201313 yr Which is a standard throttle? As I've only seem to of found fast or slow action. As I wanna change it as its got too much play in it due to the usual wear! If there is too much play (have to rotate throttle quite a bit before the slide in carb raises, thus "initiating" VRROOOM) You may want to try adjusting your throttle cable first before changing anything. Just use the adjuster on top of the carb. It may be that the cable has stretched a bit and that's all.
August 17, 201313 yr ACU license? Do I need one before I do a trial? Or can I just get a day one just to start? Licence rules! (ACU) It's called a registration and costs £10. they run from 1st Jan to 31st Dec. They don't do one day tickets in Trials like in they do for Enduro. You have to be a member of an ACU club and then they will give you a unique code and then you can apply for one. Some clubs will let you ride if you turn up and join their club, with a fully completed application form in a paid envelope so they can endorse it and then they should post it. They can be renewed online but if it's your first one you will need to attach a passport photo to the form post it, Here's a link to the application form; http://www.acu.org.uk/Uploaded/1/Documents/2013-licences/2013-ACU-Trials-Registration-Form.pdf Rick.
August 17, 201313 yr Author "Fast action" is the standard throttle. Its got white tube. The slow action throttle got a black tube. You dont say your age, but I assumed you have done at least most of your first 20 years? 250 is a good choice and yo should cope OK with standard throttle. Most adult people make the mistake thinking they need a 300... -Jan i am 32, ye i was even thinking maybe a 200cc but the 250 came along at the rite deal. Was a lucky buy to be honest ye would never go for a 300
August 17, 201313 yr Author If there is too much play (have to rotate throttle quite a bit before the slide in carb raises, thus "initiating" VRROOOM) You may want to try adjusting your throttle cable first before changing anything. Just use the adjuster on top of the carb. It may be that the cable has stretched a bit and that's all. Thanks for that!! I forgot about adjusting it on carb lol. I will try that tomorrow. But it does have a bit of wear inside the domino throttle sleeve, probably go away if i adjust it. Just looked today and its got the slow one on it at the moment...But i guess i wont know which to go for until i take it out for at least a hour
