September 23, 201313 yr do the main bearings on a montesa cota 200 1982 trials have to be put in a big press or can i carefully tap them in?
September 24, 201313 yr Are you going to do this yourself Ben? If so, could you follow-up with a report on how it went, tips, tricks, special tools, etc.?
September 24, 201313 yr Author yeah not sure if he dealers doing it or me. i would love to. so yeah ill let you know what i do. are you having the same trouble?
September 25, 201313 yr yeah not sure if he dealers doing it or me. i would love to. so yeah ill let you know what i do. are you having the same trouble? My bottom rod bearing is bad. I figured while I was in there, I would do the main bearings, crank seals, etc. I thought I had a local shop lined up to do it, but now I can't get a hold of him. Southwest Montesa has (had?) all the parts that I need, but they need a measurement off the rod to know which one to provide. I'm really tempted to try splitting the bottom end myself, but haven't worked up the nerve yet!
