November 4, 201312 yr I am by no means an expert rider, but I am not a complete novice either. For the last couple of years I have been practicing on a Scorpa 175 4t and am now thinking I would like something more competitive. I like 4 strokes, so I'm thinking Montesa 260, or Beta evo 250/300 4t. From what I have read, I think I would be better with the Beta than the old Montesa, but it's possible the new 260 is a different beast? If I went for a Beta, why would I pick the 250 over the 300 or the 300 over the 250?
November 4, 201312 yr beta 300 has quite a bit more go than the 250 ,,and i think has'nt got the throttle lag of an older 4rt ,i've got a mont and a beta and both are excellent bikes and given a little time you should find both are good.couple of friends have tried the mont and struggled and since bought betas that there both happy with. also beta has more lock on steering and the mont has better suspension.....take your choice.
November 4, 201312 yr Author Power and novice friendliness wise, would the 300 4t be similar to a 250 2t? And would the 250 4t be similar to a 200 2t?
November 4, 201312 yr i'd say the 300 4t is has as much power as a 300 2 stroke just the power seems longer and more linear,i think it's easy to ride as well,the 250 i rode felt a bit flat to me but i've only had a short ride on a 250.
November 4, 201312 yr The new Mont 260 is definitely worth considering, it's brilliant. :-) If possible, try and get a test ride of each bike, then you will be able to decide yourself. Edited November 4, 201312 yr by shedracer
November 4, 201312 yr Or you could save a lot of money and buy my 2008 Scorpa SY200F.......you won't find better ! Cheers John
November 5, 201312 yr The new Mont 260 is definitely worth considering, it's brilliant. :-) If possible, try and get a test ride of each bike, then you will be able to decide yourself. where in the uk could you test ride a 4rt?
November 5, 201312 yr where in the uk could you test ride a 4rt? I know St Blazey have a demo and some practice ground at the back of their shop, but maybe there might be one a the BVM test later in the month?
November 5, 201312 yr Author i'd say the 300 4t is has as much power as a 300 2 stroke just the power seems longer and more linear,i think it's easy to ride as well,the 250 i rode felt a bit flat to me but i've only had a short ride on a 250. I hear people say "don't go for a bike with to much power, a 250 (2 stroke) will be more than enough". But there aren't many used Beta 250 4t's. So what I'm asking is will a 300 4t be a little pussycat if I want to ride it like that? As well as having enough poke to get the adrenalin flowing occasionally? Do the Beta's have soft and aggressive ignition maps as standard? Do they make much difference?
November 5, 201312 yr I am also trying to decide between these two bikes. 1) which one is quieter? 2) I know the monte is very reliable, is the beta as reliable? (I've been wrenching a lot on my current bike and I am tired of it!) 3) who makes the Beta engine? Thanks
November 5, 201312 yr Oh, I forgot; 4) Which has the least engine braking? 5) which is the most descrete so my wife won't notice it in the garage?
