Tys 175 Choke
sykes
hi all
i seem to have the choke stuck on the bike....i took the cable of at the top of the carb and the spring is ok but it looks like the choke is stuck in the up (on) position as i take it the spring should push it down once the choke lever cable is released? so looks like the choke slider seems to be stuck to the sides of the carb
anybody else had trouble with this and any ideas how i could free it without damage.?
cheers for any ideas
the choke on my 2007 bike is operated by a lever on the handlebars which in turn pulls a cable that goes into the carb, so it looks like when i pull the lever on the handlebars it pulls on the cable and pulls the choke to the up position in the carb, which i take it is the on position...when the lever is released it looks like the spring thats encased on the cable end on top of the carb pushes the choke slided back down to the off position....i think the older models just had the pull up push down directly on top of the carb but the cable setup is meant to be more convenient.
the problem looks like the slider is maybe seized to the side of the carb as i gave it a bit of a push and it would not move so seems to be stuck in the up position
looks like a bit of cloudy fluid around the top of the slider so i am thinking if it was maybe water getting down the cable to the carb and then reacting with the different metals between the carb and slider and causing it to stick....i just dont want to put too much pressure on it incase i damage it so was wondering if anybody else had problems with this and how to go about fixing it.
i know this is a bit long winded but it hope it is a bit clearer.....as mud..
  • 3 weeks later...
