Explorer To Trials Bike Conversion
The explorer is based on the trials bike and I made the conversion....
4 screws for the sub frame, one in front of the tank and a hidden one under the seat, two cables, open the fuel line with snap closing and you can take away the Explorer kit.
Trials plastics can be mounted on the normal fixing points, for better slow motion trials I prefeer changing the front sprocket from 11 to 10 teeth.
A real dual purpose bike B)
Edited by hendrik
  • Replies 37
  • Views 14.4k
How long did it take you?
The 2014 model has the Easystart box under the seat - that would have to be moved someplace, I don't think your model has that- yes?
I have the easy start too, engine even starts on second kick without the box, conversion needs about an half hour, easy job...
Made the first trials training today, runs good, easier to handle without the Explorer Kit, only on slippery wet or muddy terrain the rear pirelli tyre is not the best choice, I let the headlight and ignition switch on its place, only a little extra weight...
Mine doesn't see to start well without it.
But I'll give it a go and see how it is. Was there anyplace to put it if you want to install the Easystart?
(I think they changed it for 2014 also, it is energized with the kill button)
Edited by lotus54
The first edition ( 2012 / 13 ) has a battery pack behind the headlight and as a refitting by the dealers the easy start ( which is nothing else than a second battery pack ) in the case under the seat, so now I have only the small battery behind the headlight.
I don't know how they made it on the 2014 model....
I mount today a layard kill swich for having more security when trying heavier things, won't kill the engine B)
The 2014 is different, the box under the seat does it all (so I understand).
Guess I'll have to see where it could be located if I ever do it. I'm not sure where they put it in the 2014 TR model.
The rather high cost of the plastic is the issue after that! Be nice to find some used stuff, but probably not very likely,
Isn't the stock lower' fuel cap,glued in on the Explorer? Maybe it is just sealer I see...
Edited by lotus54
Hendrik, beware:
2014 explorers have the new "seasy start system" under the seat. It is a black box that includes the capacitor.
The 2012 and 2013 only had a battery behind the headlight... but the factory "recalled" all those bikes to install a capacitor under the seat!!! it is not a "second battery pack"!
Hendrik, the fan will not spin at the right speed if the battery runs out and the result will be a seized piston...
Ok, I will take care of my battery, in normal trials practise the engine won't get so hot that I will have overheating problems and on road and trails use, the capacitor is installed ;-)
My dealer, who is very engaged in OSSA, tolds that its no problem to trial without the capacitor, my Explorer is the third one which is used as trials bike and Explorer....
Where is the easy start system located on the 2014 trials bike ?
It's normaly must be the same part as on the explorer, I don't think that OSSA will use different parts for the bikes.....
Wether its a different part, it will be no problem to order it....
Edited by hendrik
The 2014 trials bike have the new "easy start system-capacitor" behind the headlight.
All the 2014 models have the same "ESS-Capacitor".
I think you will need a different electrical wiring harness if you want to install the new easy start system...
By the way, who is your dealer?
Hi Mark,
Keep in mind that capacitors do not like heat so keep it away from the exhaust system.
Bill
he-he I am just doing this conversion on my 2012 Explorer. Almost done, just waiting for the airbox cover. My 2012 explorer - from brand new - came with a battery behind the headlight and a capacitor (the black box) under the seat. I moved the capacitor up behind the light and spliced it in there.
Since my wife will use the bike from time to time, I'll swap the seat back on. It will take about 5-10 mins tops.
I strongly advise to *not* remove the capacitor. It will help to remove transient voltage spikes which could cause problems with the CDI and other electrical devices. (I know this from experience)
Edited by trialtrial
can you show me a pic of the new place of the Capacitor ? ( I want to keep the original headlight )
I cut the wings off the capacitor, wrapped weather stripping foam around it, then strapped it to the battery under the instrument cluster. I considered making a bracket, but wanted to test out this location first before doing something more sophisticated.
I wired it in as follows:
* Red lead on capacitor to red lead on head light connector
* Black lead on capacitor to the black wire on a plug that had a black wire and black/wire wire. I wired it to the wiring harness side.
I will permanently leave the capacitor here. It will make swapping the seat on and off easier.
thanks, I will mount the capacitor before next Trials practise, this weekend is Classic trials seasons start and I will take my TL250 out of the garage....
