Montesa Cota 247
Ah - I have a stainless steel one - thought you'd found a new alternative !!!!
Have you decided on a maiden outing ???
Keep me posted - I'll try to get there too!
Cheers
The Wobbler
  • Replies 125
  • Views 30.6k
Most Popular Posts
  • johnmartin247
    johnmartin247
    O.k it is a bit overdue but the painter was a perfectionist So here is the finished item.
  • ]just thought i'd put a couple of pics on now paints done managed to get a airbox off ebay this morning.a friends bringing it over on Sunday. Not had a reply over seat.but its an holiday over here s
  • Hi its seems to have taken an eternity,but the montesa is finally complete. A combination of being let down by parts suppliers,lack of motivation,because of part supplier and work meant it took far
Hi John
The bike looks great,
Ive ordered some taper bearings from in motion so all the front ends off.but im struggling to get the old cups out.
you and Wobbler fitted some so any tips,
On the early frame they knocked straight out,but the later frame seems to have a internal seat,
Advice would be appreciated
Cheers Steve
Also does it say what model the double seater is on your logbook as it doesnt on my Spanish one,It might help me track a seaf down
Edited by quo 1
Hi Steve, the old cups were a bit of a challenge to get out, i used a old 18 inch socket extension to drift them out.
The dual seat bike is not road registered, it is the other one that is registered.
Let us know how you get on.
Cheers
John.
A wee update, new seat unit should be here tomorrow and the tank/seat unit is off to a custom painters who is more than eager to do the job, if it is half as good as he says it will be I will be delighted, he is talking gold leaf instead of gold paint for the coach lines on the tank and finished off with high gloss lacquer. :banana::D
cheers
John.
Hi
Well, after about 2 hours and god knows how many attempts i finally got the bearing cups out using an old long plug spanner sat on the cup lip wedged in by a screwdriver top and bottom
A couple of cracks with a lump hammer, bingo job done.
Still waiting for new bearings and other parts to arrive
Not been idle tho, three hours with an abrasive wheel and lots of spit and polish this into this
Cheers Steve
Spare engine in - fired first kick !!
But them just revs up on its own !!
Crank seals ??
Any thoughts
Cheers
The wobbler
John - don't think so - as it opens and closes freely.
Was a bit rushed yesterday so I'll have another go today.
Looks a bit naked with no tank cover on ???
Cheers
The Wobbler.
Have just been about where you are on the revving problem. It sounds like maybe base gasket or as I see a snout mount
Mikuni, could be a rubber problem.
Good luck & keep us posted.
Larry
Gents
Thanks for the comments.
As ridiculous as it sounds I think it could be a combination of things.....
I've swapped everything off my other 247 engine ..carb .....carb to head manifold and throttle cable.
Everything seems just a little bit out !!! Throttle cable too long ....I had a longer one made as it was catching on lock ...So I'll try the old one again ...I'll also take the carb off and check all of the connections etc ......
At least it runs and its not too rattly !!!!
Cheers
as always
The Wobbler.
Hi Wobbler, did you have any joy with the feel of the clutch the other week? I am just of to the garage just now to change my g/box and clutch oils and was wondering what you used in the way of oils.
Cheers
John.
John,
Not really - I don't think you can really improve the feel with the standard steel plates.
It works ok but is either in or out - you can't feather it like a more modern bike.
One of the lads I know has had some plates reworked by putting some fibre on every other (like a modern clutch). He has then fitted a longer brass bar to push on the spider so it clears.
His is a 349 though - and I'm still trying to find out where he got it all done ......
I've just used standard oils as original.
If you try something else I'd be interested with your thoughts ?? As I didn't feel the problem was oil related but facing related!!
On another note - my throttle is sorted - I had a modified throttle tube that I've stupidly replaced with A standard one - hence it wasn't shut off properly
Cheers
As always
The Wobbler
I think it was 200cc of 10 - 30 engine oil for the clutch ( daft as it sounds ) and 300cc of 80 weight gearbox oil in the gearbox as I remember.
I'll confirm tomorrow if you like ??
