Stiffen Suspension?
  • 2 weeks later...
Increasing spring preload will not make the spring stiffer, it can only change ride height
The only way to make a spring stiffer is the increase the wire diameter or decrease the amount of coils
So, the only way to make a suspension "Harder" as you describe it to replace the spring with one of a higher rate
