May 2, 201511 yr Is this for reducing / increasing clutch pull? I've been having some issues with arm pump during long practice sessions would like to reduce the pull of my clutch a bit as my Ossa's pull is about 2x that of my Sherco. I'm a novice rider and won't be doing any 4th gear splats for some time I imagine... Anyone know anything about this? Seems like a new part. Edited May 2, 201511 yr by bigmark1972
May 2, 201511 yr Clutch becomes heavier on these if the fibre clutch plates swell,which sometimes happens if ATF is used in the gearbox .You need to remove and measure the thickness of the clutch plate pack which should be 9.85 mm max .You can get thinner steel plates to achieve this Theres info on this on the GasGas forums
May 3, 201511 yr It appears this can be set in 3 different positions in order to set the finger height of the clutch pack for different lever ratio. End result the same as adjusting the pack thickness. cool idea
May 5, 201511 yr Author Clutch becomes heavier on these if the fibre clutch plates swell,which sometimes happens if ATF is used in the gearbox .You need to remove and measure the thickness of the clutch plate pack which should be 9.85 mm max .You can get thinner steel plates to achieve this Theres info on this on the GasGas forums I've not used ATF but the clutch has definitely been dragging more lately despite adjusting the MC to max stroke. Pull seems harder too than when I put it in at the start of the season. I'm going to try one of these rings to see if it helps, will report back when I've ridden with it.
November 3, 201511 yr Author OK I finally bought one of these buggers. I am thinking for easiest clutch (least pre load) pull I want to set it up with the fingers as low as possible (I have a new clutch and it's fat) am I thinking correctly?
November 4, 201511 yr No, you will want the clutch fingers high (within the specified specs) Edited November 4, 201511 yr by crazybond700
