Beta Middle Box
Hi, how easy is it to open up beta evo 250 middle box for repacking? We have packed silencer, but it's still very poppy and crackly, any easy or a direction on what to do?
Regards,
Ian
Are you sure that you haven't re-packed it too tight?
Thats what I did the first time, wedging as much stuff in there as I could, and it was terrible!
You don't need to pack it tightly..... Good luck!
packed it fairly loose ish, still loud, then rammed in a mega stack, still loud!! ??
Sound like middle box???
Ian
Have the 2 o rings inside the front end of the middle box perished?
(they seal the front pipe to mid box)
Mine had and it did sound a bit poppy.
If you're new to trials bikes you may be unaccustomed to how much compression a trials bike actually has. It's not uncommon to be sitting in line at a section and be hit by a pulse of air from a bike some distance away. A healthy bike will sound poppy at low RPM.
