January 10, 201610 yr Does anyone know if the odi lock on grips will work with a trials bike? I've just picked up a scorpa this morning. My first trials bike but I'm into mx. I've tried a few grips on the mx bikes and eventually settled with ODI Emig lock on grips. I've only moved a set once when I had the biggest moment of my life lol. Will they work on a trials bike? They sell then as 2 stroke or 4 stroke with a couple different throttle attachments in each set. For anyone who hasn't seen these grips before, the left side locks on with an Allen key and the right side actually replaces the throttle tube. Thanks, Carl
January 11, 201610 yr Hi Carl, The ODI throttle tubes may not work in the Domino trials throttle housing. There is a trials bolt on grip solution offered by S3 ... just google "S3 trials grips". Andrew
January 11, 201610 yr Author Cheers Andrew, I'll look into those. If not I did a little reading last night and domino grips seem to come out on top usually? Carl
January 11, 201610 yr Just by some normal medium trial grips of domino, s3 or some other brand. They do go quick, but have good grip and are thin enough.
January 11, 201610 yr Author I've ordered some domino dual compound. I've used the normal grips on my bikes and always had mixed results. Not keen on wiring them and the glue never lasts long. I'll see how I get on this time though!
January 11, 201610 yr Try using masking tape round the twistgrip barrel and then contact cleaner to lubricate the grip as you put it on. Once dried the grip won't move.
