webbo250 Posted January 29, 2016 Share Posted January 29, 2016 Hi, Does anyone know if a rev3 rear wheel will fit straight into an evo or does it need different spacers ?? Quote Link to comment Share on other sites More sharing options...
wmc37 Posted January 29, 2016 Share Posted January 29, 2016 It needs different spacers. Quote Link to comment Share on other sites More sharing options...
worldtrialchamp Posted January 29, 2016 Share Posted January 29, 2016 I tried this but the disc fouled on the caliper Quote Link to comment Share on other sites More sharing options...
steve_earle Posted January 30, 2016 Share Posted January 30, 2016 The Rev 3 hub is set up for a different rear caliper arrangement and they changed also from 05 onwards on the Rev. Get an Evo wheel you will save yourself a headache spacing and re spoking to get the rim central. 1 Quote Link to comment Share on other sites More sharing options...
worldtrialchamp Posted January 31, 2016 Share Posted January 31, 2016 I dont think the offset was different (although I didn't measure it), but I'm confident it will fit, it's just the discs were slightly different diameter and may need a spacer on each side as the EVO swingarm is slightly wider at the rear. BETA UK list a spacer kit for this but they've discontinued it Quote Link to comment Share on other sites More sharing options...
