April 30, 201610 yr I've just re assembled the front wheel and put it back on my bike. Is it me or does everything seem a pain to do on this bike!! I ended up having to slacken off both fork clamps and move the stanchions upwards just to align the brake plate, admittedly I haven't yet fitted the rear wheel. Then I struggled to fit the spacer and speedo drive, there didn't seem enough room. I've given up for today, maybe a couple of pints and some sleep will help!!
April 30, 201610 yr When first building the forks and wheel I find it better to fit the wheel before the mudguard stay then adjust the fit of that to the mounting holes on the fork legs this way there should be no misalignment which could restrict the smooth operation of the forks. Edited April 30, 201610 yr by trialsrfun
May 1, 201610 yr Author Now I'm having fun with the back wheel! Typical Ossa, bent spindle. Is there anywhere I can buy a stronger one from? When I stripped the bike over 2 years ago it was a pig to remove, I had to drift it out but thought that it was just age that caused it.
May 1, 201610 yr Steve Sell Marlimar OSSA makes a really strong spindle from stainless steel which will not bend, also a sprocket carrier which uses modern Beta/Gasgas 4 bolt sprockets. Drifting the spindle out wrecks the fit of the hub bearings.
May 1, 201610 yr Author I've replaced the bearings on both the front and rear,and the spokes, and the tubes and tyres, brake shoes.......I tried Steve Sell before but he never replied, looks like I'll have to try again. Cheers.
May 1, 201610 yr Steve's Ossa business is part time, not his day job, but he will reply to phone calls when able as long as you don't block your number. He doesn't, as don't many of us, answer if a number is blocked.
May 1, 201610 yr Author Could anyone pm me his contact details please, I can't find where I've put them. Cheers.
May 2, 201610 yr Funny, having the same thoughts when working on Beamish, after the Ossa I found it obstructive and awkward. Maybe just one of those days?
May 3, 201610 yr Author I wish it was just one day!! It seems to be every time I work on the thing! Makes working on old Brit bikes a walk in the park ?
