October 9, 201610 yr Hi, can anyone recommend a decent bike pump you can carry in a bum bag? I've had 2 before with a co2 inflator built in but neither work well. Looking at MTB kit but seems expensive Cheers
October 9, 201610 yr I carry a Topeak Race Rocket MT in my camelbak when mountain biking; it doubles up for the trials bike. Good features are it has a small hose so is easier to use than the pumps whose body connects directly to the valve stem. The 'MT' version is worth getting as it is high volume, low pressure for mountain bike tyres, so better for a trials tyre than a road pump which is low volume, high pressure.
October 9, 201610 yr You might still find some CO2 inflators at Aldi I think it was. Much cheaper than branded MTB stuff.
October 16, 201610 yr Author Thanks Neil's on wheels, I got the topeak pump from Wiggle delivered in 2 days. Looks a decent bit of kit and pumped my rear tyre up to 5 psi easily. The nice bit of detail is it has a flexi tube built in to attached to the valve Top marks and quite cheap direct from wiggle cheers
