October 21, 20179 yr Factory recommends 0.7-0.8mm, but I've found it as 0.5mm in SHERCOUSA booklet..any suggestion?
October 21, 20179 yr Mr Turtle correctly quotes the NGK catalogue ?✌️ (Well, my 2016 edition anyway)..... 0.6 mm is the way to go
October 22, 20179 yr The 0.5 recco was written long ago based upon the original Ducati ignition. The later Leonelli would do 0.7 just fine, and I suspect the current Hydria will be even better at it, thus the .7-.8 recco. Take advantage of all you can get for better ignition.
October 22, 20179 yr Author As it seems 0.7mm would be good to start with (as soon as I convince that Sherco clutch to let go). Thanks guys!
