mcman56 Posted November 13, 2017 Share Posted November 13, 2017 Can you grease the shock bearings on a 2014 Sachs shock? Mine is out and I have tried to tap out the top hat internal collars but they do not budge. Quote Link to comment Share on other sites More sharing options...
turbofurball Posted November 13, 2017 Share Posted November 13, 2017 Yes, my other half replaced the bearings in her Sachs, the top hats are pressed into the bearing so you have to use a lot of force to remove them. After trying different things I had the most success with putting the shock in a vice and using two big screwdrivers, one each side, to lever it out. Maybe there's a special tool I don't know about though, lol Quote Link to comment Share on other sites More sharing options...
technowaldo Posted November 13, 2017 Share Posted November 13, 2017 Think they are meant to stay dry it looks like a chromed finish on the bearing surface Quote Link to comment Share on other sites More sharing options...
turbofurball Posted November 13, 2017 Share Posted November 13, 2017 3 hours ago, technowaldo said: Think they are meant to stay dry it looks like a chromed finish on the bearing surface That would be why the ones we replaced were almost solid with rust, then. Replaced with self-lubricating ones which might last longer, but were a PITA to fit as they have tighter tolerance for the press fit (and new o-rings, with plenty of grease on them to try and keep the crap out). Quote Link to comment Share on other sites More sharing options...
sirdabalot Posted November 13, 2017 Share Posted November 13, 2017 I've found a lot of the spherical bearings fitted to shocks are Polytetrafluoroethylene (ptfe) coated inside the outer bush with a chrome plated spherical bush in the middle. They're intended to be used dry but eventually the coating wears through, I've been told adding lubricant to these types of bearing can accelerate wear, but once they've worn through the coating there's nothing to lose by adding waterproof grease. Quote Link to comment Share on other sites More sharing options...
