turbofurball Posted December 6, 2017 Share Posted December 6, 2017 Is there any trick to checking the oil levels? Or do you just have to drain them out and refill on a regular basis? 2 Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted December 6, 2017 Share Posted December 6, 2017 You've sussed it. Quote Link to comment Share on other sites More sharing options...
turbofurball Posted December 6, 2017 Author Share Posted December 6, 2017 Urf. Would be nice if there was a dipstick or sight window ... or even if the gearbox drain plug exited on the bottom ... Quote Link to comment Share on other sites More sharing options...
spen Posted December 6, 2017 Share Posted December 6, 2017 I dip a cable tie in..... 1 Quote Link to comment Share on other sites More sharing options...
turbofurball Posted December 7, 2017 Author Share Posted December 7, 2017 The clutch oil filler is right above the clutch itself, but I'll have a bash once the right amounts of fluids are back in it, maybe there's a way Quote Link to comment Share on other sites More sharing options...
fiona Posted January 7, 2018 Share Posted January 7, 2018 The clutch side has a bolt you can take out to check the level (so if too much oil in it will dribble out). 1 Quote Link to comment Share on other sites More sharing options...
turbofurball Posted January 7, 2018 Author Share Posted January 7, 2018 Thanks, I'll have a look! Quote Link to comment Share on other sites More sharing options...
