K-Scan for Ossa
4 hours ago, daveraw70s said:
Hi Lotus. Can you direct me also to K scan? daveraweng@hotmail.com
Out of interest, where are you located ?
Dave
Hello
I sent link also- but then I saw you perhaps already have everything.
I’m in the Northwest Corner of Washington State- USA (right across from Victoria, BC Canada)
  • Replies 127
  • Views 35.3k
Most Popular Posts
  • K-Scan works for me under Windows 10 (Pro x64 is the only version I've tried). My new favorite USB to RS-232 converter is made by Okiwan.  It uses the FTDI chip.  Here is an example: https://www.
  • The software was freely shared by OSSA even when they were still active.      (The owner says they are making e-bikes now, would Iike to start motorcycles again.  But I’ll believe that when I see
  • Patric, check you private message.
Tomorrow I will create a mega account a share a public link for everyone. There is nothing to worry about share a software of a failed company .. Al this secret is absurd. ;) Thanks
     (The owner says they are making e-bikes now, would Iike to start motorcycles again.  But I’ll believe that when I see it).
Been working with Konrad on my 2014 Ossa, in  the process of building an interface cable, need to get K scan software please help.
Any idea if K scan will run on Windows 10?????
okapal@outlook.com
I've add you to the share folder
okapal@outlook.com
Good luck! On Windows 10 there is no problem on software from my side. But I'm not able to have it work reading ECU serial and also I'm not able to have the ECU remap software work. Both are not capable to read ECU information! All the to other function work great .
  • 3 months later...
Hi lotus, I recently bot an 2012 explorer, and 3 rd ride out it stuck in 6th gear. I live about an hour from you, would pay to have it fixed.
Please call or text me at 425-327-0804.
I emailed you.
glad to help.
  • 3 weeks later...
Hey guys,
I´m new in the Forum and like it a lot!
Nowhere else I did find as much inforamations for ossa like here.
I´m going with a Ossa 280i 2012 and am interested in sensordata and therefor I´d need the K-Scan..
It seems that I can´t send private massage...
Could anyone send my a link or software?!
You´d make a really happy chap out of me^^
best from Loweraustria
Patric
Edited by stou
Thank you so much!
You made my day!
  • 3 weeks later...
Hi everyone, I also have the same problem.
I managed to recover a connection cable used, but I don't have the software ?
In my Ossa 300 a too quiet mapping has been planned and I would like to modify it with something worse.
If you can turn it over to me I would be very happy
bernardi.simone@live.it
Thanks
You arrive .. Thank you you are great !!!
As a note, the 300 Factory I owned was VERY aggressive. I used the ‘slow’ map switch position, changed to slow throttle and installed one tooth larger countershaft sprocket to tame it down for my ‘intermediate’ skills.
I am not sure how much difference between the factory and standard 300 models.
Thanks
Check your emails.
Thanks
This is rude, he wrote me in the chat insulting me because I didn't reply within 24 hours by sending him the software. he is a poor, rude Italian, don't pay attention, we are not all like that;)
