Fantic 200 rear wheel spacers
Hi, I’ve recently purchased fantic 200, the chain is being pulled to the outside of the drive sprocket ant rear sprocket is only 2mm from rear shock. Does anyone have the measurements for the rear wheel spacers as mine look like aftermarket.
thank carl
Take the spacers out, refit the wheel so that the rear sprocket lines up with drive sprocket and measure what spacer is required.
It has been know for folk to mix up the spacers and put the left one where the right one should be
Edited by ourian
My left spacer is 14.8mm and the right is 27.4mm. That leaves less than a millimetre clearance which is then taken up by flex in the swinging arm when everything is tightened up.
Thanks for info, I’ll check mine see how it measures up ??
My left 14.8mm & my right 35mm
my front sprocket is fitted with the raised side to the engine
