Varlo Posted August 18, 2018 Share Posted August 18, 2018 Hi, I’ve recently purchased fantic 200, the chain is being pulled to the outside of the drive sprocket ant rear sprocket is only 2mm from rear shock. Does anyone have the measurements for the rear wheel spacers as mine look like aftermarket. thank carl Quote Link to comment Share on other sites More sharing options...
ourian Posted August 18, 2018 Share Posted August 18, 2018 (edited) Take the spacers out, refit the wheel so that the rear sprocket lines up with drive sprocket and measure what spacer is required. It has been know for folk to mix up the spacers and put the left one where the right one should be Edited August 18, 2018 by ourian 2 Quote Link to comment Share on other sites More sharing options...
Varlo Posted August 18, 2018 Author Share Posted August 18, 2018 Thanks for info Quote Link to comment Share on other sites More sharing options...
b40rt Posted August 18, 2018 Share Posted August 18, 2018 Something like this makes it easy to get the line reasonably accurate. https://www.fountaindirect.co.uk/vessini-wet-room-surface-channel-10mm.html?gclid=CjwKCAjwh9_bBRA_EiwApObaOMzojicq9Buq-FjXeec8Cb_oFX5qKKpd3HSEsrJpLRpVDIYeueIi7RoCjL0QAvD_BwE 1 Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted August 18, 2018 Share Posted August 18, 2018 I'll try to remember to measure mine tomorrow morning. 1 Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted August 19, 2018 Share Posted August 19, 2018 My left spacer is 14.8mm and the right is 27.4mm. That leaves less than a millimetre clearance which is then taken up by flex in the swinging arm when everything is tightened up. Quote Link to comment Share on other sites More sharing options...
Varlo Posted August 19, 2018 Author Share Posted August 19, 2018 Thanks for info, I’ll check mine see how it measures up ?? Quote Link to comment Share on other sites More sharing options...
Varlo Posted August 20, 2018 Author Share Posted August 20, 2018 My left 14.8mm & my right 35mm my front sprocket is fitted with the raised side to the engine Quote Link to comment Share on other sites More sharing options...
