October 1, 20188 yr Hi all just wondered what map setting most run there bike on ? Know some people say doesn’t make much difference also what way does the switch go for wet and dry setting ? Also done two small trials on my new bike had about 3/4 of a can of fuel through it and is smoking when you open it up, I’ve not really had it opened up as small trials and knowntge garage put a lot of oil in a full tank of petrol has anyone had similar ?
October 1, 20188 yr Switch to — is for wet, O is for dry. Think of the O as the sun (the sun only remains a thought now here in the UK). Your other problem, throw the old petrol mix out and start with a new correct mix.
October 1, 20188 yr Author 9 minutes ago, dmc2028372 said: Did you buy it new? Yes is new by two small trials
October 1, 20188 yr The user manual has stuff in like mapping switch and lots more. http://trsmotorcyclesuk.com/tech/ Edited October 1, 20188 yr by gasserguy
October 1, 20188 yr TRS recommend only 50cc to 5lts and definitely no more than 60cc 2017 TRS One RR Keihin PWK28 carburetor (all engine sizes) Gasoline - Minimum octane USA – 95 (Ethanol content must be 0%) we recommend race gas, no ethanol Premix ratio – 100:1 (absolutely no richer than 80:1) Float height – 19mm Main jet – 125 Needle – JJH (3rd clip position) Slide size – 3.5 Pilot (slow) jet – 45 Choke (starter) jet – 62 Air screw standard position (factory setting) – 1.5 turns out Edited October 1, 20188 yr by taff_d
