December 30, 200520 yr Do you still have to remove the flywheel cover and clean/dry out after every wet ride? Are the carb flooding problems cured? Are the electrics sorted? Son is considering buying one it's between a beta and a scorpa and i can see i'll be left doing the maintainance Edited December 30, 200520 yr by windlestone
December 30, 200520 yr It's only 3 bolts to remove the flywheel cover. Wash the bike, remove the cover and lean the bike over to the right to drain any water inside, start the bike and let it run until hot, kill the engine and spray the flywheel and cover with WD40, refit or leave it off until you next use the bike. Also cut a 'V' shape out of the bottom of the cover so that any water that goes in, comes straight back out again. Don't p*** about sealing the cover on, as it's easier to whip it off after each wash. The leaky carb is still the same, JLI's will cure it for
December 30, 200520 yr Author Buy a Scorpa - no sorting and lower maintenance + Great Bike <{POST_SNAPBACK}> seen my mate trying to get the carb off his sy250 looked a nightmare kinell is it the stators that were the electrical problem ? any ideas if they are cured ? thanks for info on covers :hat:
December 30, 200520 yr Buy a Scorpa - no sorting and lower maintenance + Great Bike <{POST_SNAPBACK}> Nice statement from a user with the name MONTMAN
December 30, 200520 yr 'Nice statement from a user with the name MONTMAN ' Did not want to go 4-stroke so went for another well engineered bike with a jap engine - and very pleased I did!
January 2, 200620 yr ive got one and so far no problems! touch wood i know TW trialssports can sort thr carb problem but mine hasnt leaked yet so havnt sent it off get a beta you know you wanna!
