Fantic 301 carb
Hi, I was after some advice please. I have fantic 245 with a 301 motor in it but the plug is always blacking up. Any suggestions on carbs and jetting? Thanks
Hi Luke7129  standard 301 Fantic Carb settings are : Dellorto PHBH 26 BS
Main Jet 102
Pilot Jet 45
Needle X5 2nd notch
Slide 45
Air Screw 1 Turn out, dont forget, with Air screw its out to weaken mixture, in to richen, also standard plug is NGK B8ES, or Champion N3, hope this helps.
Those specs from 'basecampkid' are spot on as per the manual, here's the page from the 301 manual with some english inserted for the other jets and floats.  I don't have a 301 bye the way, just a copy of the owners manual.
It wont load, other specs are 70 choke jet, BN 264 Needle Jet, 8.3 gram floats.
Edited by fourex
Manual specs wont load.
Thank you very much guys ?? I’ll get the carb to bits and see what it’s actually running on.
You need to make sure the exhaust system is not bunged up, this will cause the same issue. The same for the air filter, needs to be nice and clean?
The exhaust is as clean as I can get it, I give it a good clean and repacked the silencer. And I always clean the air filter every couple of trials
Main Jet 102
Pilot Jet 45
Needle X5 2nd notch
Slide 45
needle x5 but i suggest you 1 st notch
