Does anyone know where this goes on the carb???
Davidstewart123
  • Andy changed the title to Does anyone know where this goes on the carb???
the two drain pipes from the carb go into a 'T' piece....I think this is the final drain from the 'T' and the end sits down by the bottom of the shock...I have seen it tucked into the rectifier bracket that sits on the back of the engine case.
https://www.trialscentral.com/forums/topic/64968-what-do-these-tubes-do-evo-4t/?do=findComment&comment=455616
the above link...if i've done it correctly, should take you to some photos I posted in Oct 17 showing the tubes on the carb
  • Thanks 1
You can see in this pic the two overflows tying together into a white plastic tee.  I think as Thall1 indicated, it may be the final hose coming off the bottom of the tee.
