jsyben94 Posted April 13, 2019 Share Posted April 13, 2019 (edited) Hi all Looking to stiffen up my front forks on my 19 Factory, does anyone know of where I could get hold of a stiffer spring ? The aftermarket one is out of stock everywhere and apparently there isn’t anyone making them. Also would using thicker oil help if so what weight could I go up to ? Thanks in advance for your help ! Edited April 13, 2019 by jsyben94 Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 13, 2019 Share Posted April 13, 2019 You got to be pretty big to need stiffer front. So did you already get a heavier rear? Quote Link to comment Share on other sites More sharing options...
jsyben94 Posted April 13, 2019 Author Share Posted April 13, 2019 12 minutes ago, lineaway said: You got to be pretty big to need stiffer front. So did you already get a heavier rear? Possibly the world biggest trials rider 6 ft 8”, 17 stone. Already got a stiffer spring on the rear already but still find it too soft, just ordered an Ohlins set up for my size. 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 14, 2019 Share Posted April 14, 2019 My little boy is 6` 5`` and 230. But, you are above average! I take it you are not in the states? Quote Link to comment Share on other sites More sharing options...
jsyben94 Posted April 14, 2019 Author Share Posted April 14, 2019 7 hours ago, lineaway said: My little boy is 6` 5`` and 230. But, you are above average! I take it you are not in the states? Negative, in the UK Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 14, 2019 Share Posted April 14, 2019 With all the Beta's in the UK you would think someone might have one. I tried a stiffer one and it was just too harsh. Quote Link to comment Share on other sites More sharing options...
hgas Posted April 16, 2019 Share Posted April 16, 2019 Just serviced my forks Can someone tell me how much fork oil goes in each fork ? Quote Link to comment Share on other sites More sharing options...
dan williams Posted April 16, 2019 Share Posted April 16, 2019 If the UK importer can’t help you you might be stuck having a custom spring wound. There appear to be four different spring rates above stock available from Beta. Suspension spring chart-2016 EVO_0.pdf Quote Link to comment Share on other sites More sharing options...
hgas Posted April 19, 2019 Share Posted April 19, 2019 I’ve just rebuilt my front forks with new fork seals , I’m now finding the forks very soft they don’t bottom out but they’re not far off ,I’ve used belray 7.5 and I followed the guide of 60 ml air gap in the damper side and 120 spring side , my question is can I just unscrew the top caps and add more oil to stiffen them up? Quote Link to comment Share on other sites More sharing options...
