August 26, 20197 yr Hi, can anyone help me find a set of levers, cable brake and clutch, where not only the pull can be adjusted but the resting position of the lever as well ? Thanks, Phil
August 26, 20197 yr https://www.ebay.co.uk/itm/NEW-MAGURA-73-74-CLUTCH-LEVER-BULTACO-HUSQVARNA-MAICO-SUZUKI-KAWASAKI-YAMAHA/163239949249?hash=item2601dbf3c1:g:gcoAAOSwOttbo7mg There ia a small setscrew that allows you to do adjustments, however position will not last for ever.
August 26, 20197 yr The old-fashioned way to do it was to put a spare chain link over the cable between the lever and clamp.
August 26, 20197 yr Author Hi, thanks for the replies but I want a pair of matching levers and I do not want to put bits where the shouldn't be, technology has evolved and there must be some decent levers out there somewhere for cable front brakes and cable operated clutches. The clutch lever and perch seems to be addressed in the MX and enduro world but noth the front brake. Phil
August 31, 20197 yr I had to look at a new pair i have. Yes correct. I had forgotten. Only the the brake levers are driiled from the factory. I had to do the drilling and tapping myself at the clutch lever.
