October 4, 20197 yr Anyone know of a cheap substitute for the TR280 fuel cap until I get a proper replacement? Up here in the GNW ordering parts take a long while to get here. Kinda need one by Saturday. Sheesh thats two days away. Does the Beta EVO fit? Edited October 4, 20197 yr by trialtrial
October 4, 20197 yr Just checked in the shed and Beta Evo doesn't ft ? If it helps Ossa thread diameter is 27mm give or take a little and Evo is 32. Both have a 3mm thread pitch. cheers, R
October 4, 20197 yr A cork, a block of balsa, a ball of masking tape, a cut down exhaust bung, they are just threads so should be pretty easy to seal Edited October 4, 20197 yr by faussy
October 4, 20197 yr Author Richard - thanks for checking and the specs. Lineaway - I will look into TRS.
October 4, 20197 yr Not sure if it would seal around the threads good enough..but how about one of those rubber expandable frost plugs, they come in different sizes?? May leak around threads enough to vent if not over torqued ? Edited October 4, 20197 yr by pauls320
October 10, 20196 yr Lewisport had a nice alloy one. I have one and it works really well. Darn stocker was a bugger
October 10, 20196 yr http://lewisportusa-com.3dcartstores.com/OSSA-TRIALS-FUEL-CAP-2011-2015_p_1459.html
