Sherco 2.5T no spark .
Bernie Onthacoast
Hi Trails gurus . I have a Sherco 2.5T 2010 . the gas tank in the seat model . It has no spark after parking up from a ride , when i went to start it a day later there was no spark . From other threads here it does not seem uncommon . However when i tried to source a new stator i  am told its no longer available . My one appears to be off an earlier model 2007 , it has 3 windings and a trigger coil . it meters out ok as per specs i got here .
Would anyone here know of the meter readings for the CDI . mine is the CDI coil in one, mounted behind the engine high in the frame.
I have been quoted $ 690.00 NZD to upgrade to a 013 stator, coil, and CDI . I am reluctant to spend this untill i know exactly what has failed on my bike. Any help is appreciated.
Cheers Bernie . Westport NZ
That looks like the one in my 07 sherco iv just had it rewired and sorted for £135 12 month guarantee  so if you can find someone over there to do am sure that's your problem mine started 2nd kick after not working for over 12 months ...to replace mine would have been £420 ?
