oil leak ty mono
1 hour ago, fastbelly said:
Take shift lever off and replace the oil seal. Easy job.
Many thanks.
5 hours ago, section swept said:
Check gearbox oil quantity as well. Check gearbox breather is clear.
Drips only came to light after draining and re-filling, so poss overfilled slightly, although pretty sure not done so.
Good point re the breather, though.
  • 2 months later...
Ok furher to above topic, just replaced gear shaft oil seal due to oil passing it, checked and refilled oil to correct capacity and checked  what I think is gearbox breather tube, which is clear............upon starting and allowing tick over, find I'm now getting oil running out from behind gearbox sprocket (gear shaft seal is oil tight)
Any idea's,.........?
Many thanks
Andy
  • 2 months later...
Mainshaft (output shaft) oil seal is shot also. The shaft your sprkt sits on.
Sounds like a lot of dried out/aged/incorrectly fitted/poor quality aftermarket seals on the motor.....
