Clutch spring bolts
Anyone know the torque for the clutch spring bolts on a beta 250 2004 model?
Cheers Jamie
Hi - I know you are looking for a number and hopefully someone will post one for you, but I go for "hand tight" if I can't find a figure - My Rev 3 had socket head screws (after I modified it) so I used a "standard" length Allen key, my Evo 4T has 8mm hex head screws so I do the same with "standard" length spanner. An old engineer told me that once and it hasn't let me down yet! I did check recently with some head nuts on another bike and the torque achieved with a standard spanner wasn't very different to that set using my torque wrench. I guess that is one reason why spanners are different lengths. Obviously different materials and different thread pitches come into play...
I'm sure there will be wails of protest from those that know a lot more about mechanics than me! Good luck
Edited by markparrish
speling!
