Limmy01 Posted April 16, 2020 Share Posted April 16, 2020 Anyone know the torque for the clutch spring bolts on a beta 250 2004 model? Cheers Jamie Quote Link to comment Share on other sites More sharing options...
markparrish Posted April 16, 2020 Share Posted April 16, 2020 (edited) Hi - I know you are looking for a number and hopefully someone will post one for you, but I go for "hand tight" if I can't find a figure - My Rev 3 had socket head screws (after I modified it) so I used a "standard" length Allen key, my Evo 4T has 8mm hex head screws so I do the same with "standard" length spanner. An old engineer told me that once and it hasn't let me down yet! I did check recently with some head nuts on another bike and the torque achieved with a standard spanner wasn't very different to that set using my torque wrench. I guess that is one reason why spanners are different lengths. Obviously different materials and different thread pitches come into play... I'm sure there will be wails of protest from those that know a lot more about mechanics than me! Good luck Edited April 16, 2020 by markparrish speling! Quote Link to comment Share on other sites More sharing options...
Drummerboy Posted April 17, 2020 Share Posted April 17, 2020 Don't over tighten, The bolt lugs can snap off Quote Link to comment Share on other sites More sharing options...
retromlc Posted April 19, 2020 Share Posted April 19, 2020 Probably 5-7 nm Quote Link to comment Share on other sites More sharing options...
dan williams Posted April 21, 2020 Share Posted April 21, 2020 Snug em. The springs will keep them from backing out. Quote Link to comment Share on other sites More sharing options...
