June 7, 20206 yr Author When it starts it seems to run fine I've changed the plug a couple of times we bought the bike new but my lad put up with it he now has given trials up so I've now inherited the bike and problem could it be a faulty CDI unit thanks
June 7, 20206 yr When CDI went on mine, it backfired badly. Clean the pick up first as they can also rust.
June 7, 20206 yr Author Ill will try that thanks but this has been doing it from brand new the bike is only 6 month old and at most only been used 10 times
June 8, 20206 yr If doing this from new might be running lean on the low end? Maybe adjust the air/fuel setting and check what jets are in it and?
June 8, 20206 yr If you have had it from new could you not seek advice from the dealer ( If they are open of course ! )
June 8, 20206 yr Author Thanks for all your advice I have spoke to tony today (road and trials)he told me to check a few of the simple things first Like carb done Spark plug done Loose connection on plugs done I'm going to try to change my cdi unit of my 2014 if it fits and then who knows
