August 18, 20206 yr hi has anyone tried the as3 wide foot pegs are they s3 stuff or someone using a close name thanks
August 19, 20206 yr Looking them up they sure seem like they are their own thing with no connection to S3 directly and the design isn't the same, though a lot like them. Looks like they only have one type that works on trials bikes though. "Trials AS3 Racing Foot Pegs" Hope someone can chime in with some experience with them and a real review for you soon.
August 19, 20206 yr 17 minutes ago, Kona said: They look very similar if not identical to the Apico wide foot pegs.... Ditto, Id say they are made in the same factory, whoever is making them
August 19, 20206 yr S3 Hardrock are good foot pegs there is also the curve which is similar but has a slight forward tilt to help if you have the front wheel up alot.
August 19, 20206 yr Author 1 hour ago, Kona said: S3 Hardrock are good foot pegs there is also the curve which is similar but has a slight forward tilt to help if you have the front wheel up alot. Thanks im after wide ones really i have flat feet narrow pegs make my feet ache after a while
August 19, 20206 yr 4 minutes ago, Robert n said: Thanks im after wide ones really i have flat feet narrow pegs make my feet ache after a while Same for me, being a size 13 boot can have some fun problems.... I use the apico footpegs personally but the S3 are very good as well.
August 19, 20206 yr Author 49 minutes ago, Kona said: Same for me, being a size 13 boot can have some fun problems.... I use the apico footpegs personally but the S3 are very good as well. 13s that’s some boot I’d looked at the apico they look good aswell the s3 have caught my eye now it’s too late ?
August 19, 20206 yr 3 hours ago, Robert n said: Thanks im after wide ones really i have flat feet narrow pegs make my feet ache after a while This is my issue as well, flat feet, and I find a mix of the S3 hard rock aluminium and the AlpineStars Tech T trials boots seem to do very well for my size 11 US feet. I think the combination of the stiffer sole on the A-Stars and the wider S3's seem to do well for me. Good luck.
