November 5, 20206 yr I m planning to purchase a used car so i need to check all the details about the car that i m planning to buy. The main detail that i need to check is whether my car is stolen or not?
November 5, 20206 yr If concerned check engine and vin number against v5 and that sellers details match v5. As above, hpi check Are there 2 sets of keys
November 5, 20206 yr Also, with no cost to you, go on the Gov' MOT checker website. This way you can check its MOT history and if your seller tells you it's a local car, the MOT garage should be local too, if it's not and the car has been MOT'd miles away, yet the seller tells you otherwise, then that's your alarm bells!
November 8, 20206 yr There is always another car or van out there, if you can be patient. If any of the above cause worry, walk away. If you dont think anythings not genuine ditto.
