November 29, 20214 yr hello, I have a problem with my bultaco sherpa. the bike don't want to take turns. it is very soft on acceleration. I have a well adjusted carburatzur phbl26. What is the problem. thank you
November 30, 20214 yr Was it running OK before you changed the ignition or did it happen after you changed to the Dellorto
November 30, 20214 yr As Sherpa325 says you must find out "what is wrong with what" before trying to rectify it. If you suspect the Dellorto, test OKO. Pay attention to the air filter and how the carb is connected to the air box. I found out this is very important OKO can be bought here http://www.mid-atlantictrials.com/Bultaco.html Edit Spelling error Edited December 2, 20214 yr by carl ekblom
December 3, 20214 yr Tried different PHBL combinations. This is one of the latest Idle 25 Needle 266K Needle jet D36 Throttle 60 Main 115 Thought first it was very nice. Strong mid throttle and full throttle Later found out it was little weak at low throttle. Perhaps PHBH is more all round. Also more period. OKO or Mikuni for Bultaco is more all round. Today OKO is my first choice. However OKO may not be permitted for competition everywhere. But flat slide is period
December 3, 20214 yr Needle JJH All jettings for 199A and OKO quite cold (late autumn) Basically the Mid-Atlanics jetting
